Slc 500
Sep 2006
AR
I was wondering if I can use a plc like a dimmer. For example a light bulb. Bring it on dim then slowly making it brighter at different times of the day?
If you want to use it in a home electrical system then the only problem is the compliance to local regulations. PLCs comply to industrial standards only. Domotica systems do comply to domestic use standards.
Kind regards,
I have a program that I've used 100 times. SQO settings: File N7:0, Mask 0FFFFh, Dest B3:1, Control R6:0, Length 8, Pos 2. Length & Position...
48
1,000
Everyone, i am in the process of purchasing the Slc 500 version of software to support what we have and i have a question. Several of our...
787
In a slc 500 plc I am trying to move data with out using a lot of moves. I want to move data from n7:1 to n7:2 and data that was in n7:2 to n7:3...
1,379
Customer has a circa 2004 SLC-500 PLC. Fieldbus is a 1747-SDN DeviceNet scanner. Customer has SLC-500 file (.rss) with no comments. Has no *.dnt...
569
After I tried wiring, I used computer program communication to read the PLC N value, but received a NAK signal. And the DL3500 CHA light keeps...
436
