SLC 505 locks up Citect
oldnerd
Mar 2011
Al
94
I have a a/b SLC 505 with a math overflow in a SCP, the S:5/0 bit is unlatched, to allow a non-shutdown fault of the processor. However when the overflow occurrs it locks up my Citect HMI screen. Anyone run into this before?
why not making your program faultless by filtering the data entering your math function to make sure you're not getting overflow trap...
Because you just tell the plc to ignore the fault, we don't know what happend with that tag and if it cause the plc to fail why not on Citec...
Clearing the fault is a "band-aid" ...
Make the input min/max snd scaled min/max and destination a float. If input min/max and scaled min/max are constant integers then force them to be floats by entering them with a .0 appended. Then recast the CiTect tag as a float.
Oh, and welcome to the forum.
Hello all. I have a few SLCs in my plant and of late we've seen a weird issue: The system will be running normally and then randomly the outputs...
123
Hello, I inherited a control system one of my predecessors thought it was a good idea to put logic for cant optimization and Kinetix motion...
3,627
Probably a silly question and asked a hundred times already, but i tried to do some searching here and couldn't find this question. I have 502's...
3,038
I'm a mega noobie when it comes to PLCs and the such. I'm a network guy. We are currently experiencing an issue where the SLC immediately faults...
1,918
Hi guys I hope your all safe and well , I have a question regarding a slc 505 on ethernet is it possible to add a ethernet remote I/O module...
1,886
