SLC5/03 connect to panelview 800
abrown01
Nov 2013
Auckland
Hi there,
I'm wanting to connect a panelview 800 to an SLC5/03 the SLC is connected to an 1747-AIC which is run to another 1747-AIC. I'm trying to figure out what cable I require to connect the peripheral of the second AIC module to the panelview. I can't seem to find any reference online. Any help would be appreciated.
Hi, I have a SLC5/03 connected to a working HMI via RE232 port, and connected to a broken HMI via DH485 (RJ45), I want to use the cable that used...
3,306
Hello, I have one legacy system that I'm trying to troubleshoot - it's a SLC5/03 connected to an old Panelmate 1785. I can connect to the SLC...
1,452
Tried a straight through 9-pin RS-232 and a null model cable. No luck so far.
1,552
Looking for some help to understand memory mapping for a slc5/05 utilizing a 1746-sn module to (2 manifolds) numatics 2.2 manifold coupled via...
2,213
Hello , im trying to connect to a slc 04 using the rs232 port but for some reason when i auto configure want let me , says check cable or switch...
17
4,329
