SLC5/03 to 1500 comms with phone line
Loordi100n
Aug 2006
irl
20
Hi there...
...Would appreciate if some1 could help me out a bit here.
Basic:
Main PLC SLC5/03 x 1
Remote PLC 1500 (LRP C) x 4
All these connected to Westermo TD-33, a phone line.
Philosophy:
Remote PLCs sends signals (alarm bits and Flow rate) to Main PLC and (then Main PLC sends all the signals to the SCADA).
Remote 1
signals ModemON
---|N7:0|-----------()
modemON Write to Main
---||-----------(MSG)
MSG sent HangUp
But a little bit more guidance I'd need, obviously :)
Just bare in mind, that PLCs are on site already.
Configuring modems (AT) is not an issue, just that ladder.
Cheers
hi i have problem with connect PV 1500 to Backup SLC5/05 Via serial Port my system as follow : primary Rack 1747-1553 , 1747-BSN...
1,904
I have wasted a week trying to figure out how to connect an SLC5/03 with my laptop. I do not have and can not Buy the 1747 UIC and PC3 cables. I...
2,580
I am trying to connect to SLC5/03 using an FTDI usb to rs232 with female to female converter at 1 end... however I can not connect to it ... the...
1,297
Good evening. I am in serious need of help. I am trying to connect a Panelview Plus 7 Standard to a SLC5/03(1741-L531) using a Moxa MGate...
654
Hi. I am having trouble establishing comms between an slc5/04 and panel view plus 7 via a PLX51-net-eni. The set up is: 5/04 Channel 0 DF1...
942
