SLC5/03 with EEPROM 1747-M11 problem Help
micgent
Aug 2009
Gateshead
52
Hi Im after some pointers please.
Im suspecting I have a faulty EEPROM 1747-M11.
Error Description 'Indexed address outside of entire data file space (range B3:0 through the last file.) Note 5/02 processor uses an index value of zero for the faulted instruction following error recovery.'
To prove the point I wiped suspect CPU RAM, took a CPU from a similar m/c removed its EEPROM placed into suspect CPU. Then 'Load from EEPROM' loaded the RAM. Changed the Node address to prevent a network clash. Programmed with user program/menu. m/c worked without fault.
Removed donar EEPROM refitted suspect EEPROM, tried to load RAM into suspect EEPROM but faulted 'Store to EEPROM failed 0x4'. Then tried to run CPU with no EEPROM fitted, but again faulted.
So I suspect faulty EEPROM.
The Link is in Un-Protect Position.
Do I have to change a BIT to allow CPU to run without EEPROM?
Will the EEPROM 1747-M13 work in place of obsolete 1747-M11?
Your help greatly appreciated
micgent
I have wasted a week trying to figure out how to connect an SLC5/03 with my laptop. I do not have and can not Buy the 1747 UIC and PC3 cables. I...
2,578
I am trying to connect to SLC5/03 using an FTDI usb to rs232 with female to female converter at 1 end... however I can not connect to it ... the...
1,294
Good evening. I am in serious need of help. I am trying to connect a Panelview Plus 7 Standard to a SLC5/03(1741-L531) using a Moxa MGate...
653
Hi. I am having trouble establishing comms between an slc5/04 and panel view plus 7 via a PLX51-net-eni. The set up is: 5/04 Channel 0 DF1...
941
Hi All, I have programmed some MSG instruction in SLC5/05 64k CPU series D FW 13 brand new cpu. 2 of the MSG instructions are direct IP to other...
991
