SLC5/05 backup
cjd1965
Apr 2007
UK
1,659
Hi
I have just had a job land on me. I need to goto site and backup a program. I have RS Logix 500 and a serial port cable and a Ethernet crossover lead. The PLC is a SLC5/05 and the photo I was sent show both ports are free
No one knows the configuration
If I try the serial port first with RS Linx and that is no good do I need to reboot the PLC to get BootP working?
I am unsure if I will be allowed to stop the process
Cheers
Hi
Cheers
If BOOTP is disabled, then cycling the power will make no difference.
Thanks for the tips... Okie I have downloaded Wireshark ..looks a great tool
First hello to everyone 🍻 Right as for the daft question......... My company has a policy that we must verify our PLC's programme every...
1,449
I have wasted a week trying to figure out how to connect an SLC5/03 with my laptop. I do not have and can not Buy the 1747 UIC and PC3 cables. I...
2,569
I am trying to connect to SLC5/03 using an FTDI usb to rs232 with female to female converter at 1 end... however I can not connect to it ... the...
1,280
Good evening. I am in serious need of help. I am trying to connect a Panelview Plus 7 Standard to a SLC5/03(1741-L531) using a Moxa MGate...
644
Hi. I am having trouble establishing comms between an slc5/04 and panel view plus 7 via a PLX51-net-eni. The set up is: 5/04 Channel 0 DF1...
932
