slc500/4 help with latch
Peternjs
Mar 2004
Need to set and reset latch by single touch input from several 550 touch screens and scada package. My logic seems to be evading all of my efforts. Input is via a b relay and momentry however the scan seems to reser the latch to quickly. I need to set and reset by one touch for about 90 inputs.
Momentary pushbuttons in SCADAs and HMIs are allways a source of trouble. You need the communications scan to be so fast that the normal (natural ?) short press of the button is "seen" by the PLC.
This method works independently of the scan rate:
Use a "latched" pushbutton in stead of a "momentary".
In the PLC, evaluate the "write" tag with a oneshot. When the oneshot is activated, do the action that you want to perform (like changing some state), AND unlatch the tag immediately .
Let the "indicator" tag be the adress that changes state.
Hello im hoping someone can point me in the right direction. I have a SLC-500 that the program has been erased. I'm being told it will require an...
1,539
Hello Guys, I'm trying to get online with a SLC 500. I've never had issues going online with it before with the current program but now it keeps...
1,419
im using Slc5/04 one of its 8 channel analog output module 1746-NO8I got defective if i replace it with new one do i have to re-program or...
3,265
I am looking to see if somebody can assist me with a pdf copy of the attached SLC500 RSS file. Thank you Jeff
1,985
I am working on a conversion from a SquareD PLC to a SLC series PLC. I have run across one issue that I can not seem to overcome. The older system...
1,677
