SLC500 - Adding Message Data Type
Ones_Zeros
Feb 2014
at work
375
Hello
I was trying to add a "Message" data file in a SLC500 PLC controller.
I'm not seeing the Message as a "type" to select.
How do I add the message as a option to choose in the type box from with the "create data file" dialog box?
thanks,
MG datatypes are only for the MicroLogix controllers.
In any SLC-500, use a block of Integer (N) data of the appropriate size. DF1 or DH485 or DH+ messages use 14 words, and Ethernet messages use 51 words.
So I would use these instructions? (DF1 or DH485 or DH+)
I’ll do some research on how to use them to message
between SLC500.
I’m not sure how to use them
Could you possibly provide an example?
Thanks for the explanation
I appreciate it
Which exact models of controllers are you using ? What sort of network connections do you have ?
What's your goal for messaging between controllers ?
Ken
Thanks for helping.
- The model of both PLC controllers is 1747-L552 (5/05)
- The network connection between these two PLC’s is Ethernet CAT5 connection.
- My end goal is to Message over several (N) Integers from PLC A to PLC B.
I will be using these Integers from PLC A to turn on a Output in PLC B
Thanks Again
Hi All: What is involved in adding a new AO card to a SLC500? From what I understand, hot swapping is not an option. So I my guess (and Im...
3,551
Slc500/04 DH, RS233 Ports are used. Verifies rs232 cable is good, Computer port is configured. Not able to go online with programming port, why?
160
Hello, I'm working on a system that was using an Allen Bradley slc500 with df1 over mds orbit radios to communicate. I have switch them now over...
18
433
I have included the original ladder from the SLC150(70127.txt), I have also included my RSLogix 500 project(70127.zip). I unfortunately do not...
165
I'm am connecting one powerflex 40 with a slc505 and a slc500 devicenet card Do I need a termination resistor? Tips tricks are appreciated
113
