SLC500 Comms to Ultra 3000 Drive
Tony Leight
Oct 2005
Newcastle
I would like to know if anyone has any experience with RS232 comms between an SLC500 and an Ultra 3000 indexing drive.
I am trying to set up a drive to index different distances with the distance to index being sent from the PLC. I have managed to manipulate the the figures I need to send and create the correct ascii string ( For a distance of 5120 pulses I believe this should be :010AF100140092^M )but I am having trouble getting the drive to read these values. This is the only function I want the comms to do as I would like the control of the indexes from digital inputs and also to be able to select a jog function on the drive.
The drive also has a host command window which I have been using to try and write my distances straight into the index 0 setup distance, but this doesn't seem to be working either.
If anyone could help with this problem it would be greatly appreciated.
Thank you for any help.
I have a machine that uses a Quartech module that communicates to Ultra 100 and 200 servo amps. It reads values from the PLC5 via DH+ and writes the numbers to the drives. I have heard that doing this with serial comms via ladder logic can get very complex. According to their website, this unit will talk to Ultra 3000 drives.
QUARTECH P/N 9112-0-1
http://www.quartechcorp.com/products.htm
We have several slc500 spread across a site. No Ethernet comms cards or anything. I need to monitor alarms on each unit and was thinking of say...
1,756
I am upgrading a Wonderware InTouch HMI application from Version 7.11 to Version 10.5 on Win 7 64 bit OS. Changing from GEHCS and ABTCP WW I/O...
1,985
R
Hello I could use some help on SLC500 Peer to Peer comms. Specifically, I have 2 5/05 processors. Master and slave for clarity's sake. They are on...
4,316
raceandski
R
I cannot add SLC500 analog input tag (I: 8.3) to EZSeries Touch Panel Editor (V 5.3). I used all the listed tag datatype but it all says "Invalid...
296
can the slc500 5/05 send a email and text over Ethernet ?
195
