Soggy Canuck
I have a SLC500-L30C fixed hardware plc with a bad comm port(someone jammed loose wire ends into the comm port a some point in time). I have another L30C lying around with newer firmware, is it possible to pull the Eeprom from the older L30C and boot it on the newer PLC? I want to pull the program out and rewrite to a different platform.
