Slightly OT: Energy metering- multiple circuits
Frank_
May 2020
Aruba
Looking for an economic way to monitor kWh and kVARh on multiple circuits (up to 10) in a single distribution board.
The Square D Power Logic Circuit Monitor looks like it will almost do the job, but for that sort of money I could afford to buy separate meters. Can anybody recommend another solution?
I have good luck with Leviton's sub metering products to monitor a building that we lease to multiple tenants. They have solutions for monitoring a whole panel as well.
A permanent solution ? 3 phase or single phase ?
For permanent use a few options below:
Veris (expensive) have lots of options
https://www.veris.com/itemLevelFilt...&resultPage=12&keyWord=&keyWordTxt=&pageNo=12
Another option is Socomec Digiware modular system
https://www.socomec.co.uk/multi-circuit-metering-measurement_en.html
Or if you want to give a startup a go:
https://www.incusense.com/
Or even simpler, depending on your load, direct in line metering, something like the CG EM range
https://www.gavazzionline.com/pdf/broemeng.pdf
I have used all of these products, it depends on your exact requirements which one you want to go for, just ask if you need an help
Looking for an economic way to monitor kWh and kVARh on multiple circuits (upto 10) in a single distribution board. Data will only be used for...
4,832
Hello all. I recently had to re install my AutoCAD Electrical 2024. I am trying to find the Rockwell catalog to install in it but cant find...
122
I have been tinkering with a little DIY remote access stuff lately, prompted by some recommendations and challenges on this forum. To my...
1,867
I need a little sanity check and hopefully advice from some experienced users. I have a mechanism that we're driving with a JVL MAC3000...
1,156
Does anyone make a "positioning cylinder" like the Festo DDPC but with a digital encoder feedback ? I have an application where a 0.0005 mm...
1,781
