Slow Release Relay in Telepace Ladder Logic
BillRobinson
Oct 2006
Sydney, Nova Scotia
185
Hi All,
I'm new to this ladder logic game and I'm writing some pump logic. The logic needs to use an equivalent to a slow release
timer; the logic has to know that a pump "WAS JUST ON". For those who don't know what a slow release time does it has the following I/O characteristics
..............................._____________.............
Input _____________|..................... |____________
.................................._____________________..........
Output _____________|................................... |_________
{slow release}
Now I've tried using a timers, to reproduce this with no success. The timers in Telepace Ladder Logic look like the following
....................Timer Start -[ Limit ]- Timer = Limit
......................................[Timer ]
.................Timer Enable -[_____]- Timer < Limit
Any Ideas?
Is this an OFF Delay situation i.e. you want to start a pump and have it run for X amount of time then stop?
If so then try latching your pump on and include a NOT T1=limit bit:
Pump On T1=limit Pump
| | Pump |
Add the timer and use the pump to enable it, when times out it should reset to zero and require Pump On button to restart.
I just took a quick glance at the software so not sure of the details or what you need.
Give this a try:
For those not familar with ControlMicrosystems SCADAPack
they scan like Modicon PLC's, Top to bottom Left to Right
Anyone have issues with RSLinx being very slow to open. It sometimes will say "Checking Activation" at the bottom for what seems like an...
156
Hi All, we've recently upgraded from FTView SE v10 to v12. Since the upgrade we've been having a problem where the HMI is slow to update tags in...
90
Hi, I have some problem with View Point which I'm using to manual control of conveyors. On begin when in network was only PLC and HMI View Point...
75
Hi. Importing a 2014 aapck in 2023: no problem using it, adding windows, works very well, no problem whatsoever. Creating a new project: as...
754
I am having a weird experience using KepwareEx6 as an OPC Server for a set of SLC processors where the tag data is not updating remotely at the...
574
