Soft Start and VFD with bypass
If desperate bypass is needed most systems have a line contactor before the VFD,just disconnect the motor leads from the outgoing VFD side and connect direct to the line contactor side feeding the VFD. Motor current protection is a problem then depending on the system configuration. Most VFD's can control the line contactor operation as well.
soft start with bypass
Try Benshaw.com, we use several of their controls for our larger air compressor motors (300HP). Also their controllers continuous;y monitor a lot of parameters allowing the controller to shutdown the motor before damage can be done.
hi
i introduce INVT inverter with water supply card. it support 4 frequency pump and work very good. I tested it.
if u have more question Email me.
what about schneider's softstarters?
They do not come with internal bypass but instead recommend usage of external by pass
I have never used Schneiders but I know you can buy the the starter with/without a bypass contactor from Benshaw. The bypass contactor merely takes the load off of the solid state soft start components because once the motor is at full speed the SCRs are essentially "ON" all the time and their function is essentially complete.
It's been a few years but I've used the Telemecanique ATS46 series in the past. In my experience, it's been a very reliable soft starter. We did use an 'at-speed' contactor on them, and if the customer specified we would add a 'bypass' contactor as well.
The application is a small conveyor that needs to speed up and then speed down so that the part gets moved down the conveyor quickly. I have...
5,577
Does a solid state soft starter have a DC Buss / DC Buss voltage like a VFD does?
253
Haven't done much with soft starts, more-so VFDs' in my time. Looking at replacing 3 x 37KW (415 V 50 Hz) star-delta starters with soft starters...
2,876
Is there a way to get the fault history from a SIRIUS 3RW4456 Soft Start through the HMI keypad? I've been through the manual but it is pretty...
746
We are going to be using a SIRUS 3RW5545 Soft Start to control a 480V, 150HP fan. Looking for some recommendations for parameters to use with this...
850
