Softlogix 5800 / Emulate 5000
Greg Dake
Jun 2005
Milwaukee, Wi
550
Hello!
I have a 1769-AENTR module, and associated 1769 I/O modules, which comprise a remote I/O rack with no physical processor in the rack.
I just built this system and am looking to test I/O but don't have a physical processor. I should be able to test I/O using my laptop and Softlogix 5800 correct?
The other software product, Emulate 5000, I am pretty sure I cannot test physical I/O from my laptop, only run and simulate the PLC program.
TIA,
Greg
You are correct; SoftLogix can perform messaging, control motion, and run I/O on Ethernet, but Emulate 5000 can only work with virtual modules in the virtual backplane.
Thanks Ken, I new this would be right up you alley and you'd respond!
On a site note, in talking with support, neither support Windows 10. Emulate 5000's next version will, Softlogix will remain at v23 forever and not support Windows 10.
That sucks, hopefully Emulate will at least get the virtual Ethernet card.
I use Softlogix all the time because I can setup comm drivers as if it were the real thing.
Hello Experts, Need help with Solft Logix 5800. I successfully downloaded my program in slot 2 controller and slot 1 controller. But my Slot 1...
3,880
Hi All, Good day! I'm having a problem uninstalling the SoftLogix 5800. I can't remove the unknown module. See below image or attached image...
2,957
Hi team,would someone know why l cant see analog cards in the drop down menu, only the soft CPU, ethernet and input/out cards only. It is the...
2,584
We are running SoftLogix PLC with RSLogix 5000. Both at V. 19 currently. Every time we save the project and reboot the computer, after starting up...
6,619
Have anyone tried to use Softlogix 5800 with Wonderwares ABCIP DAServer? I'm using RSlogix 5k version 20 and will use ASP otop of that...
1,381
