Solenoid Air Valve and Solenoid Vacuum Valve
Tofo
May 2013
CA
57
May I know whether they are the same thing?
Can I use a regular Solenoid air valve to gate vacuum?
The MAC valves we use are rated for both pressure and vacuum. However, if you're using a valve with an air-actuated pilot, you would need to supply external pressure for it--vacuum won't operate the pilot.
To elaborate: Many valves are actually two valves in one. Since the solenoid is relatively small, it actuates a tiny valve called the pilot. Pressure from the pilot is what actually shifts the main valve. (Think of it like a small relay driving a contactor.) So even if the main valve is rated for vacuum, you still need pressure for the pilot to work correctly. With some valves you can specify either an internal or external pilot; internal means it uses whatever is fed to the main valve.
Kolyur is right on the money. I know Ross Valve also makes some vacuum rated valves as well. Depending on the size needed that have a new 'Dale' series which is a smaller manifold type and also larger line mounted valves.
Numatics and SMC might also but I've only ever used those for non-vac applications.
Haven't had much luck with SMC for vacuum operation.
ASCO works well, they have vacuum rated valves also. However I have used some of their standard oil/air valves to 10-5 Torr.
It really depends on:
1. valve size
2. pressure on inlet of valve
3. vacuum on outlet of valve
4. how fast you want to flow through valve when open (CV)
A little information about the application and the specific valve will be helpful.
I don't recommend diaphragm type solenoid valves in vacuum unless you're in the barely vacuum range, above 300 torr (Thats atmosphere down to -8 psig for us Yankee Luddites 🍺)
That said, you can sometimes get away with using a diaphragm type valve on clean vacuum at lower pressures if you mount the valve upside down so that gravity is working with you to move the membrane away from the valve body orifice.
I wouldn't do it... But...
A couple of decades back I was asked to take a look at small table top vacuum lab furnace. It would pump fast down to about 75 to 50 torr and then slow to a crawl. It would not go lower than about 500 millitorr no matter how long you let it run. The roughing valve was a diaphragm type solenoid valve. Once pressure dropped low enough there wasn't enough differential pressure to lift keep the weight of the diaphragm off the orifice. I recommended that it be replaced. Customer said "OK, but what can we do now till we get the right valve?" I flipped it over upside down and pumped down to around 50 millitorr in very little time but wouldn't go much lower. IMO that was still not satisfactory, however the customer thought I was a miracle worker. Sometime later he had me back to do something else and I noticed that he had never replaced the valve.
Moral of the story: Don't be enamored by the simplicity of a solution that isn't really a solution.
If this is a high-vac application then its best to use a valve designed for high vacuum. If cost is an issue then you can get good performance from a vacuum rated ball valve with a rotary air operator attached to it and use a small 3-way/2 position solenoid operated air valve to pilot the rotary actuator.
Did you find a valve to work?
So what is a good 24V Solenoid valve to turn Vacuum On/Off?
1. valve size
Good piece of information
Hi All, Solenoid bank controls air to 8 cylinders. We used to able to move cylinder up and down by hand no problem but now there is a small amount...
2,452
Hello ! I need help to understand these arrows on this solenoid this solenoid is activated electrically by 110 VAC and it is being used to...
1,919
Hello all, I am a beginner and am requesting some help. I have been tasked with a program in ladder logic where once the start button is pressed...
23
2,029
I have a SC9-LS24-3 surge protection solenoid cable from automation direct...
1,359
Hi Experts! I'm trying to control a solenoid valve (don't have part number, but I've been told its a 24V DC 30 watt coil) with a PLC output card...
6,617
