Solutions in servomotors for printing industry
blima
Aug 2010
Lisbon
96
Hello!
In the next year, my company is going to change a printing machine, that uses a single DC motor with a long shaft, for several servomotors in a shaftless solution.
At this point I can only find solution in Simotion Siemens, but I'm enrolled in their courses, but because of the lack of students, they have been postponed.
That made me wonder if the market is choosing other manufacturers. Can anyone point me other solutions providers? With courses and service support in Europe?
Thanks,
Bruno
I would look at Yaskawa they have Electronic Line shaft synchronization package that is right in line with what you need.
Using standard motors and drives ( Not servo ) I know they can do it at a much better cost. Much simpler programming direct drive to drive master reference. Manual bump up or down to allow the operator to sync the print units.
Best would be to find a good rep or consult the factory.
I would at least look at Bosch Rexroth. We have had very good luck with them in some fairly demanding applications. They also have a pretty good selection of ATEX motors available, which you will likely need in at least a few places on the machine if you are printing.
Keith
Control Techniques M700 has Electronic Gearing as part of the Advanced Motion Controller, which is an integral part of the parameter set.
That drive can run Induction, Synchronous, or Servo.
Hello, I am looking for a solution to remotely access any kind of device securely across the internet. I know this has been done in piecemeal...
22
2,240
I swear I post this yesterday but can't find it. Don't see any notification about the post removal either. Maybe my memory is malfunctioning...
2,573
Seems like this is a huge cluster with Emerson supporting the Proficy software and GE supporting the old stuff like Cimplicity and Versapro...
2,582
We are a lean manufacturing company. We set up assembly cells in our clean rooms where we will configure a line of portable equipment to assemble...
2,654
The NoGoes so far are Wonderware InTouch Machine Edition is junk, it freezes constantly when debugging scripts. Currently using this :shoot...
22
3,783
