SoMachine basic. HMI
Qulu Quliyev
Jun 2016
Baku
As far as I know, SoMachine basic is for programming plc using ladder logic diagram. Is it possible to program HMI using this software ?
Any help is highly appreciated.
Best Regards
http://www.schneider-electric.ca/en/product-range/2226-somachine/
"SoMachine is a unique solution software for developing, configuring, and commissioning the entire machine in a single software environment, including logic, motion control, HMI, and related network automation functions. Thanks to many predefined templates in SoMachine you save engineering time by applying complete libraries or even a new machine module."
Regards,
Hello Qulu Quliyev
In case you still need more information:
SoMachine Basic is used for programming M221 controllers, supports Ladder and Grafcet.
There is a small display TMH2GDB available that you can connect to M221 controllers' SL port. This can be easily configured in SoMachine Basic.
To connect bigger panels like Magelis you need to follow this video https://youtu.be/fEWU3zoOwbg
Remark:
SoMachine and SoMachine Basic are two different software for different PLCs families.
Hi all, I've been trying to develop modbus rtu program between uv balasts and plc ı'have 6 slave balast.I am reading fault run voltages etc...
1,209
hello eveyrone I want to make an application with M221 PLC in SOMACHINE BASIC program. I request your valuable help. I have a 50 ms pulse...
1,612
Hi Guys, I'm using M221(TM221CE24R) PLC and SoMachine Basic from Schneider and having a bit of problem. 1. I can't able to read the data from...
1,752
Hello, I am new to plc programming. I am trying to program a flow meter (E&H promag 50) in somachine basic to achieve the following: 1...
2,413
I downloaded SoMachine Basic, I'm looking to maybe use an M241 in an upcoming project. It seems that the basic vs, doesn't offer Tag based...
3,065
