Some confusion with Factorytalk View Tags
Sep 2022
Earth
Hello,
My apologies in advance if this is a stupid question. I have done a fair amount of work in Factorytalk View machine edition, and I am having to edit someone elses program currently.
I am used to seeing connection tags in a format such as this..
{(PLC)jogspeed}
but in this program I am finding stuff like
{#1.jogspeed}
{#6.pump_speed}
I am not sure what these # are representing?
I was thinking that maybe they reference local tags to a routine, but the numbers don't seem to match up to that.
Thank you in advance for anyone who could offer me some assistance to this!
They represent parameters from either a parameter file or passed to the display via /T in the display command.
Those are referencing a Parameter File or Parameter List, typically used with Global Objects. If you scroll down in the Explorer on the left side of the screen, there should be a section you can expand called Parameters. In there should be a list of files, probably with component names, and when you open them they should open like a text file that looks something like this:
!============ Parameter File Created 2021/11/15 ============
! Parameter files are used with graphic displays to specify the tags a display
! uses at run time. You assign parameter files in certain application components
! and object properties dialog boxes. Please see the Help for details.
! Syntax:
! #replacement=tagname
! Example:
! #23=A_COLOR
! #23 in any expression in a graphic would be replaced by the tag A_COLOR.
#4={[SD]oit_real[27]}
#10={[SD]oit_real[23]}
#21={[SD]oit_int[50]}
#5={[SD]oit_bool[85]}
#11={[SD]oit_real[24]}
#22={[SD]oit_int[52]}
#6={[SD]oit_real[25]}
#12={Air_Flow_Description}
#7={air_mass_units}
#13={[SD]oit_bool[83]}
#8={[SD]oit_bool[86]}
#14={[SD]oit_real[26]}
#9={[SD]oit_real[22]}
#15={[SD]oit_real[26]}
So here is where you assign PLC tags to the numbers, and then you can reuse the same single screen (like a PID or VFD control faceplate) and just have the PV always assigned to #1, SP to #2, etc. You would then make a button that calls that global object (PID-52 for example), and link it to the parameter file or list for PID-52.
Hello, all, I am new here and pretty new to PLC'S. Closest thing I have to PLC experience is with avionics. At my new job I am a welding engineer...
824
I am working on some documentation in preparation for updating firmware around our plant. On one particular PLC, the point IO has two different...
726
When enabling a FOR instruction does the index set to the initial value before the first execution of the Called Routine? e.g. Initial Value = 6...
1,485
I'm looking to purchase either GX works2 or works3 for a Q series rack I purchased off of ebay. Now the confusion comes from either purchasing...
1,383
I have a possible project fixing a customer's old machine that is using a ControlLogix 5550... but I need to have v10 installed. Up to this point...
4,063
