Somewhat OT, but I need.....
David_Emmerich
Sep 2002
Smiths Grove, KY
671
Hi group,
I need a single phase 120vac speed control for a 1/2 hp gear motor, that is running a hoist on a degreaser system we are building. I know, DC or 3 phase would have been a better bet, but this is what I was handed, and it's already installed in the machine...I just hate picking up the pieces....
Any thoughts?
David:unsure:
Change to a three phase motor, use a VFD.
In almost every case, speed control of a single phase AC motor is impossible, unless you have a very special motor, in which case you would have spent more for the very special motor then you would have for a three-phase motor and VFD.
Dave
I don't think anybody has asked it 3 phase avaliable to you or do you have to have a single phase system. Either way I like everybody else has said can only offer to 3 phase it. We have some little drive boards in a ITW melt system that are pot setup no programming. 2 screwdrivers and you can have them running off single phase.
Hi group,
Any thoughts? David:unsure:
Dave
For sure in degreasing I would consider total enclose motor because of
1. Goop dirt etc in motor
2. Solvent interaction with windings (degradation of insulation and or phosgene generation with chlorinated solvents -- as an example)
3. Flammable solvent considerations.
Is speed control really mandatory - can you leave well enough alone? Nice to have and all that but,,,,
Think VFD fed from 120 single phase (unless you have 3 phase) and 1/2 HP 3 phase motor is way to go. Too bad they did not think of this up front
BUT
It is job security !!!!!!!!!
Dan Bentler
Take a look at the ABB ACS55 if a VFD is an option. 120V single phase in, 230V three phase out. Program with 8 dip switches and three pots.
Doesn't get much easier.
This is a bit off-topic in a strict PLC sense, but it is in the process measurement area. I need to strip some Alpha 9058C coax to mate with TE...
21
4,859
Just throwing this out there since there may be some who aren't aware of the differences between Pozidriv and Phillips screwdrivers - or even the...
4,290
Hi all, just wondering if there is a list of resources and locations somewhere on this site? Would this be a good thing? I happen to be in need...
1,613
I have been involved in panel design and building for nearly 18 years and have used various methods for supporting and/or rigging the panels while...
30,854
Hi. I have a HMI program made with WinCC Flexible, and it shall be displayed at an exhibition on a 43" widescreen monitor. I think it is a HDTV...
3,182
