SQO File.
PhilipD
Nov 2009
Humboldt, TN
117
I have searched and searched but I cannot find an answer to this question. Can an input file be used as the file reference using a MicroLogix processor?
I'm not sure I'm phrasing this correctly. This is what the MicroLogix manual says: File is the address of the sequencer file. Make sure to use the file indicator (#). This file stores the reference data for monitoring inputs. I have tried to use an input file but it will not accept the "#" indicator.
Hope it is clear about what I am asking. Thanks.
Short answer is yes. Post your .RSS file with the error (zip it first). It should accept the "#".
When you say it won't accept what error do you get?
Which ML are you using?
Mickey,
Thanks, but I have figured it out. Well, I don't really have it figured out but it is now working. I must have been doing something wrong when entering the address but danged if I know what it was.
Again, thank you.
I am reasonable familiar with with rs500 sequencers (by no means an expert) but this format of addressing the file on a SQO has me stumped...
1,536
I have a program that I've used 100 times. SQO settings: File N7:0, Mask 0FFFFh, Dest B3:1, Control R6:0, Length 8, Pos 2. Length & Position...
48
979
Hello I am trying to make a program work with a sqo instruction .The process has 5 steps ,and a starting step of zero.There should be 8 sec...
17
1,067
I am working on a machine that is using the SQO instruction to step through a cycle, but I am getting lost following it. I have not worked with...
18
3,468
I have an air press that I built ages ago, and it has been running forever. It was originally designed with Rotary Cams and Air actuated buttons...
1,510
