Square D Sy-Max PLC
fredjohns
Dec 2008
Pennsylvania
119
We have a few old Square D Sy-Max PLC with a Mod. 500 processor. We have been using the SFW-375 software and a PC to communicate with the PC when we needed to. We use a NR&D SC902 programming cable to connect the pc to the plc and this has been working good for a year now.
Today we had the problem where we hooked up the PC to the PLC the same as always and when we go online with it we get the message:
UNABLE TO INITIALIZE ASYNCH
We tried using out spare cable but still get the same message each time. Does anyone have any suggestions of what we might try to get them communicating again.
When I check the utilities menu in the program here is the setup:
System Card: ASYNC
Com Port 1
Route: NONE
Baud Rate 9600
Any help will be greatly appreciated.
Fred Johns
Just guessing here. Sounds like it might be a comm port problem on the computer. Check your CMOS BIOS setup to see if the port is enabled. If you have 2 comm ports on the computer try changing to COM 2 in the software and the cable. Even if you dont have 2 ports you might try setting the software to COM 2, reboot the computer, then change back to COM1, reboot again and try it. Hopefully your spare comm cable you switched to is ok also. Just some ideas, good luck.
hello i had a pallet nailer go down yesterday the CPU appears to have had better days. I was wondering if anyone new about these old Sy-max PLC's...
1,960
Square-D Symax SFI-324 I have used the SFI-510 card for many projects, but I came across a SFI-324. Does anyone have ant tech info on it?
86
Hi everyone/anyone.. I am looking to program an old Square D Sy/Max Model 300 processor with 8 slots of I/O, wondering has anyone had any...
2,453
We are looking to install a Sy/max DLM-110/120 D-Log data controller module to our Sy/Max 400 PLC system in order to collect some PLC register...
1,486
Hi, We are getting an intermittent 20001 error on our old SquareD PLC. It has 3 remote racks in close proximity and every few hours seems to drop...
1,943
