SST-PFB-SLC module connect to siemens CPU-300 with DP port
sdhiraj
Nov 2006
India
Hi All,
I have siemens CPU-300 with DP port. which i am using as master for DP slave. Now i had some SLC IO which i want to connect to the same profibus network using SST-PFB-SLC profibus scanner.
I have made this SST-PFB-SLC scanner as slave but unable to see the perticualr node in siemens hardware configuration.
please tell me how to connect these SLC IO with existing STEP-7 CPU-300.
You have to install the gsd file for this particular card. You may have the file with the CD that came with the hardware or from their website.
Siemens hardware config. display siemens hardware only by default. You have to install the GSD files for any non siemens hardware, then you can view and configure them in Hardware configuration.
Thanx Rohan,
i have done this part already. I need procedure to configure this card. dp you have any pls send.
i am looking for a profibus scanner SST-PFB-SLC Version 1.0 for SLC 5/03, but it's hard to find. I see the same model number, but version 2.0 on...
2,505
hey guys i would like to say this is the best place i have found for plc ???? so this is where i come for my ? i have a sst-pfb-slc card. the...
3,301
In a 1756 Controllogix(CLX) chassis there is a SST Profibus module, i have the configuration Software for CLX but do not know or have the...
6,801
I have 2 SST-PFB-CLX modules (Slot3 and Slot6) in my 1756 A/B PLC. Both modules are working O.K. I tried to upload actual configuration using SST...
1,733
I need to set up some messaging between an old Simatic TI 545 PLC (part number is 545-1104) and a ControlLogix L55. I have an SST-PFB-CLX module...
10,016
