sst profibus eds file
matt_o
Jul 2003
Hoping someone knows how to obtain an eds file required for the configuration of an SST-PFB-CLX profibus scanner module in a controllogix plc
You only need a GSD file if you're making the PFB-CLX into a Profibus DP slave to some other DP Master. Then you can import the GSD into a tool like COM Profibus and use it to tell the Master how to parameterise the PFB-CLX as a slave.
Otherwise, you just need SST's configuration software, free with purchase of the module.
I used one of these to scan a slave CTI module in a TI-505 rack a few weeks ago, also to scan TI-505 "Profibus RBC's" to control racks of I/O that formerly belonged to a TI-545 PLC. They're pretty clever once you get them going, but if you're not accustomed to Profibus they can be a little dense.
Just to clarify my query, we are trying to communicate to the SST-PFB-CLX over ControlNet and need a EDS file to configure it using "RSNetworks for ControlNet". I have been unable to download it from http//www.controlnet.org because the link to the eds page is broken. Do you have any suggestions?
(Daniel, the sst site does not provide the eds file I need)
Thanks a lot,
matt
Huh. I've never seen somebody put one in a remote chassis before. Does SST say you can do that ? The I/O connection to the CPU is relatively colossal and I think it would hog quite a lot of ControlNet bandwidth.
What do you expect RSNetworx for ControlNet to do with it ? I mean, an EDS will allow you to have a module icon for it, but not a whole lot else. I thought the 1756-CNB in the chassis provided proxy services for unidentified backplane modules.
I'm asking these questions also because I don't know where to get an EDS for this device. I have a PFB-CLX in my office but I dunno what happens when you browse it in a remote backplane.
Thanks for your thoughts Ken... It sounds like we've been given a near impossible task. We're a couple of 4th year Elec Eng students that have been given this gear to get going for a project. Who ever purchased this gear has put no thought into it.
Back to the drawing board!
Thanks again,
matt
SST-PFB-CLX EDS File
You don't need the EDS file. As Ken already mentioned the ControlNet RSNetworx configuration will post this device with a yellow question mark. It would be nice if a an icon showed up for the devices. I have two of these devices in my Local ControlLogix chassis. I have been having trouble with the 17-slot chassis picking up the 2nd module (different problem!). I don't think that Woodhead cares too much about providing a data sheet (EDS) for this module. However, don't give up on it. It is a viable hardware bridge between PLC's that do not normally communicate well with one another. We are using it to have CLX PLC's communicate with TI/Siemens IO.
Just to clarify my query posted recently, we are trying to communicate to the SST-PFB-CLX profibus scanner over ControlNet and need a EDS file to...
7,499
Hi experts! Is there a compatibility of firmware version between PLC L72s and SST-PB3-CLX-RLL profibus scanner ? I upgraded my PLC firmware from...
1,226
Hello Everyone, Have some cards Profibus SST-PB3-CLX Card that after power down, when back online again just said EB14 error. Anyone know this...
2,153
Hi guys, I am in need of some advice from people with experience with the above. I am currently replacing a client's SST-PFB-CLX profibus...
6,434
Hi there! I am trying to connect my SST Profibus in our Controller using RSLinx Classic. When I right-clicked my Master SST and then go to the...
2,671
