Starter ethernet connection problem siemens S120 control unit
chandrapaul
Mar 2016
bangladesh
119
Hello,
I have connected ethernet cable with my laptop and the s120 control unit. setup my laptop ip 169.254.11.1 and subnet mast 255.255.0.0 , selected access point S7online (step7), pg/pc realtek pcle gbe family controller tcpip auto 1 (active). then trying to find access nodes. but its showing no device found. please check all the attached images.
i am new with this software. please help me someone.
Those are Profibus CU320's - I would connect using Profibus or possibly via the CPU's ethernet port if it has one.
I connected directly to the CU ethernet port.
Yes, I can see from your picture you are connected to X127
I suggested you connect either via profibus or the Ethernet connection on the plc if there is one.
As there are no connections on the X127 ports the implication is that they are not being used.
LD
Hes just trying to connect using Starter.
X127 using his pc and Ethernet should work easily
What are your thoughts ?
I've never used the X127 connection - I've always connected via the plc. The OP should refer to the starter project for his system as a start point.
Is there any other progamming cable that is can use to communicate? With g120 I use USB cable. That works very well.
See post 3
In IP address of sought node
Put 169.254.11.22
Also turn off virus protection temporarily
Also, try another laptop?
Looking for Ideas for a distributed control system and need to start a 10A Motor (DOL) or Revsing (DOL), would rather have a EthernetIP conncetion...
2,493
Hi Everyone, Looking for a "Sanity Check" on my programming for Starting and Stopping a pump connected to a SMC-3 Flex Soft Starter via...
2,568
Hi all. I am trying to figure out how to connect STARTER v4.1 to MM4 on a customers site. I want to install STARTER on the customers PC, and...
8,777
253
Hi, I want to start 150 SMC Flex from Studio 5000. I have the AOP and P SMC flex AOI imported in my program. I have also set the logic mask to...
359
