static electricity
plcnewbie
Jan 2005
Missouri
220
We are currently haveing an issue with static on our line. We make a paper product that gets cut and as it passes out of the saw house it picks up static and causes the top layer to lift up. How do you elmiate this static??
A real easy thing to do when paper is involved is to add humidity with humidifiers or misters.
If it is paper products, misters won't be as good a choice as the humidifiers. I find that information given by pc_geek to be pretty intersting, esp on EXAIR products. It looks very costly too!
Tinsel
plcnewbie
Have you tried using metallic tinsel over the top of your product?
Pass the tinsel over the product so it lightly touches. With it connected to a ground source, such as your earthed frame, static is picked up and neutralised. Cheap and quick as an interim method.
I'm sure you can experiment with other conductors if you have no tinsel to hand.
Peek at this http://www.school-for-champions.com/science/static_materials.htm
I work with rubber coated wire products which build up huge amounts of static. We use metal brushes that are grounded and touch the surface of our conveyors and product. They are simple and cheap. Ours are made of brass, but still do a good job in our application without scratching the surfaces too much. We get them from a company called Akron Brush according to my storeroom catalog.
They make a variety of anti-static units but tinsel is cheap and works good if the system allows room to use it.
http://www.statictinsel.com/
You can also look for static cord or static brushes. These are called passive static eliminators. If the process is too confining or static builds up too much then you may need an Active or long range static eliminator.
http://www.fraser-antistatic.co.uk/Products.htm
http://www.amstat.com/
In most cases your existing ink or paper supplier can offer an anti-static product.
Hi, Does anyone have any experience with hydraulic fluid static electricity affecting electronics?
1,774
Is there any product available that can limit the amount of static electricity generated by 23000 colors and 15000 cottons that are on a loom...
2,779
T
guys: I have a problem with my IP configuration. my organization networking has 2 subnets. 10.0.0.25 and 10.1.0.25 both under 255.255.255.0 all...
567
Hi Yes, I'm stuck again. Trying to define a Function Block. What I've put in there so far has been a straight copy/paste from the code (and that...
22
2,898
Hi; In our Corrugator plant, there are automatic WIP conveyors having two moving carts also. System contains 17 items (server, two PCs, Siemens...
2,438
