step 5 for DOS program files Structure
netvisor
Nov 2003
25
Hi all,
Just wondering if any step 5 " experts" out there could take the the time to explain the files that pertain to a plc program and how they interrelate to each other when using step 5 for DOS.
I understand that there is a program file , a symbol file and several other files.
What I would like to be able to do is back up every couple of months all these files to a server from the laptop and when required actually be able to use them after I copy the latest revision back to the laptop or perhaps use an old revision if needed.
I know step 5 is very fussy about where the files are placed in relation to each other as obviously the path must be also stored in one these files(I assume???).
If anyone can explain it would be a great help......
Regards
Tom
?????ST.S5D is the program sorce and
?????Z0.SEQ is the symbolic address/description sourse you not need others for backup.
S5-developper generates xref-files and symbolic .INI-files from
those 2 files.
If you use a footer, you'll also need to backup ??????F1.INI or ??????F2.INI. The F1.INI file is a 80 character footer, the F2.INI is a 132 character one.
Furthermore, what Seppo told is correct: the rest can be genereated by STEP5 from the ST.S5D and the Z0.SEQ.
Kind regards,
thanks guys
So I take it if I need to do a restore I just point my step 5 software to the location of the program file and the documentation files and thats it????
What about project files ????how do they work???
Regards
Tom.
Project files?? What version of STEP5 are you talking about? Or do you mean the PJ.INI files used from version 6 on? Well, these you can rebuild when you enter where those others (ST.S5D etc.) are located.
Kind regards,
I am having a step7 v5.4 program where the blocks are encrypted and locked. And the manufacturer is stopped the support. Is there any ways to...
180
Good Morning, Hoping someone with some Siemens experience can give me a hand with this one. Customer has a S7-200 cpu, which has a 6GK7...
251
HI! HOW COULD I OBTAIN THE NAMES OF THE STEPS OF A ROUTINE IN SFC LANGUAGE IN STUDIO5000? Or is there a system variable that gives me those...
341
I'm just trying to figure out the right method of adding a DO card to an existing rack. It's not the *next* open slot, but I have to move the AO...
551
Hi Siemens Experts, I am hoping someone can shed some light on my issue. I have uploaded the code from a S7-300 (317-2PN/DP) using Step 7...
685
