STEP 7 Code To Interface Multiplexed BCD Displays
TodHead
Sep 2011
Aberdeen
Hi All,
Desperately looking for STEP 7 code example to help urgent project!
I am wishing to interface 5 (five) multiplexed 6 digit BCD displays. As a guide I have the original STEP 5 code - unfortunately I am not familiar with STEP 5 at all (and am new to STEP 7!) but can glean the main principle of the method.
The first output word that is output to the display(s) is constructed as follows:
Hi order byte:
bits 0-3: BCD bits 1,2,4,8
bits 4-7: Display Digit Select 1 to 4
Lo order byte:
bits 0-1: Display Digit Select 5 to 6
bits 2-6: Display No.1 to Display No.5 Select
bit 7: Flash 1
The relevant bits of the second output word that is output to the display(s) are:
bit 1: Flash 2
bit 2: Flash 3
bit 3: Flash 4
bit 4: Flash 5
I have an STL routine for non multiplexed displays that I can deconstruct as a starting point but I would rather have a LAD/FBD template as a starting point.
Surely someone has done this before and can give some guidance to this classic exercise?!?
Example attached.
I put decimal data in the temp area for testing purposes. You will need to copy the data you wish to display into this area instead of my test data. Similarly I have created the multiplexed bits in the stat area of the FB, you will need to assign these to your actual output bits. I tested this in plcsim using single scan mode and monitored the instance DB to check the correct bits came on.
Thanks for your help L D[AR2,P0.0] I will have a look at this when I go on shift tonight. We have been given a solution in SCL which may work...
I had an FC which specialized for computing energy or power consumption by shift - day - year and so on. this fc is called in a function block to...
2,094
IS it possible to write this on a better way: L #db_Num2 L 121 ==I JNB _02 CALL "CONT_C" , "DB_reg_igla1"...
2,648
Hi all, I'm doing my Final Year Project on a liquid level / temp control system, Using an S7-300 and Simatic HMI, as well as a PC (MPI...
2,399
Hi guys First, sorry about my english and thank you for your attention. My situation is pretty complicated because i am pretty new to this...
5,066
Hello, I a would like to create a rolling average for a flowmeter signal. I'm quite new to Siemens Step 7 - does anyone have a FB or can paste in...
9,028
