STEP 7 simatic manager and field PG problem.
Feb 2014
Jamshedpur
Hi all,
My siemens field PG is not getting on suspected some hardware fault, now to hook up with S7 400 PLC i have installed simatic manager in a different laptop but the license remains in the PG which i am unable to transfer. I have installed simatic manager in a different laptop and used a basic step 7 license available ,
when i get online in logic and i can view in run mode but unable to search the variables options or go to option by search, seems any problem with basic license or how can i set this right ...🤞🏻
till the time i buy a fresh engg software step 7 with license??
I wanted to search variables by right mouse click and go to read/write options.
The license in the PG is probably a PRO since your refer to the other as BASIC.
With BASIC you can download and go online, and also search addresses, no problem.
PRO is the same as BASIC, except it also includes GRAPH, SCL and PLCSIM.
ok thanks do i need to copy the symbols of address description from backup program as i have uploaded the current from the PLC, maybe i need to then check the search variables process.
You should use the backup with symbols and declarations to work on.
If you are in doubt if your backup matches the PLC program, then do an offline/online compare.
Hello Everyone Im Trying to Study a PLC programm of a Pet Blower machine, it is programmed in Simatic Manager Step 7 in STL/AWL Lenguage in a part...
Hi , I am working on Siemens CPU 315-2DP(6es7315-2af03-0ab0) while working online i try to modify bool value memory address M33.3,M34.0 but it is...
2,361
Is there a way to zoom in, in Simatic Manager? I have an extremely high resolution monitor (3200x1800) and it's hard to read. I know that I can...
2,470
Hello everyone! I've just stared with programming on STL and I have problem which I can't understand. I'm writing programs on Step 7 and I'm...
2,203
Hello everyone! I've just stared with programming on STL and I have problem which I can't understand. I have this piece of code:
1,960
