Step 7 Temp Local variable.
shaun_nel
Sep 2009
Ladysmith
Hello All,
I am not new to Step 7 programming but I am also by no means totally conversant in all the methods available to "create" the desired software for the clients purpose.
I have recently moved across to a new plant where the suppliers have used FBD as the default programming language and there is a liberal use of local TEMP variables between networks. (See #Tmp_Bool in attached screen capture.)
I don't understand what the purpose of the re-use of the #Tmp_Bool variable is in this situation? Why not just use a different variable each time, so that the normal plant tech like myself can see where the data is going?
How would a person follow the logic if each network output end in #tmp_bool?
Any help will be greatly appreciated.
Thanks,
Shaun Nel.
He's using a temp bool to complete a network that needs a coil but his logic has no need of a coil. His network is all about the 2 move instructions, he wanted them to be on the same network but 2 moves in parallel need a coil at the end to complete the network.
I usually call the bool a 'dummy' when doing this.
Another reason people use a scratch, is if the network is too long to reasonably monitor, so they split it into 2 or 3 networks, using a temp bool to pass the status from one to the next.
I am having a step7 v5.4 program where the blocks are encrypted and locked. And the manufacturer is stopped the support. Is there any ways to...
181
Good Morning, Hoping someone with some Siemens experience can give me a hand with this one. Customer has a S7-200 cpu, which has a 6GK7...
253
HI! HOW COULD I OBTAIN THE NAMES OF THE STEPS OF A ROUTINE IN SFC LANGUAGE IN STUDIO5000? Or is there a system variable that gives me those...
343
I'm just trying to figure out the right method of adding a DO card to an existing rack. It's not the *next* open slot, but I have to move the AO...
557
Hi Siemens Experts, I am hoping someone can shed some light on my issue. I have uploaded the code from a S7-300 (317-2PN/DP) using Step 7...
690
