Step By Step Tutorial on Logging from a Do-More PLC
gclshortt
Dec 2014
Ontario
3,217
This series will walk you through the steps to create and implement a robust PLC data logger using the following equipment and hardware.
•Automation Direct – Do-More – H2-DM1E PLC (Ethernet Modbus TCP)
•Do-more Designer 1.3 (Simulator instead of PLC mentioned above)
•Windows based computer running IIS
•Visual Basic 6
The tutorial is free to use.
http://accautomation.ca/now-you-can-have-robust-data-logging-for-free-part-1/
Let me know what you think.
Thank you,
Garry
http://www.accautomation.ca
The robust logger will log the information in the PLC using indirect addressing. If communication is lost, the information will still be there until the computer retrieves it and places in the database.
Regards,
Garry
Fantastic write up Garry! Thank you for taking time to help other people out with getting data logging going with Do-more!
I am having a step7 v5.4 program where the blocks are encrypted and locked. And the manufacturer is stopped the support. Is there any ways to...
192
Good Morning, Hoping someone with some Siemens experience can give me a hand with this one. Customer has a S7-200 cpu, which has a 6GK7...
258
HI! HOW COULD I OBTAIN THE NAMES OF THE STEPS OF A ROUTINE IN SFC LANGUAGE IN STUDIO5000? Or is there a system variable that gives me those...
344
I'm just trying to figure out the right method of adding a DO card to an existing rack. It's not the *next* open slot, but I have to move the AO...
558
Hi Siemens Experts, I am hoping someone can shed some light on my issue. I have uploaded the code from a S7-300 (317-2PN/DP) using Step 7...
695
