Step7-200
ielkhatib
Apr 2020
Egypt
34
Hello guys đź‘‹
I have been working on a problem with Siemens step7-200 CPU 226-CN,
It was burnt out and I couldn't found the these Chinese version of the PLC,So I bought the original version, I contacted the manufacturer and they gave me a copy of the software , but now I have troubles downloading the software because the software has BGN_ITIME, CAL_ITIME , they're incompatible with the cpu...
Anyway to solve the problem.. or to get around them using original timers..
I haven't used either of the instructions, so don't ask me for more information.
A copy of the Siemens Manual:
https://cache.industry.siemens.com/dl/files/582/1109582/att_22063/v1/s7200_system_manual_en-US.pdf
Page 203 for BGN_ITIME.
Page 78 you could use ReadRTC and store it, Read RTC again and subtract one from the other.
Or use a millisecond timer T0 or T32 or T64 or T96, obviously make sure they aren't used anywhere else.
https://support.industry.siemens.com/tf/WW/en/posts/time-counting/68322?page=0&pageSize=10
https://support.industry.siemens.co...and-cal-itime-blocks/38840?page=0&pageSize=10
Incompatible with the CPU or with the current CPU firmware version?
Maybe its a matter of updating the CPU FW to the latest compatible with your hardware.
I have been using TIA portal 13 for several projects HMI. The HMI is 1200 panel. On the previous project, I could connect to the PLC and use...
26
18,780
Good morning, i have step7 10.5 basic that works fine with 1bd30 cpu, but it seems supporting only old cpu. now i would buy a 1bd40 cpu, but the...
1,214
Hi everyone, In need detail explanation regarding RTC block in ladder diagram.(how it works,its register etc) help me bye
1,656
I have an opportunity to quote an HMI project for one of my customers. It's a small project, and the customer is not the type with deep pockets...
24,867
I’m trying to connect to a S7-200 plc with a pc running STEP7-MICRO/WIN v4.0.0.81 and a PPI to USB cable. This connection worked fine before. But...
4,350
