Step7 Screen Not Updating
hein123
Aug 2010
Uitenhage
93
I have an irritating problem with Step 7.
When switching between windows (Alt-Tab), the screen does not want to update. I then have to switch back to the old window and back again a couple of times for the screen to update.
Or scroll up and down.
Does anybody know if there is currently a fix for this?
I am running VMware V14, and it is a Windows 7 PC with Simantic Manager V5.5 SP3
Any advice would be appreciated
I have been using TIA portal 13 for several projects HMI. The HMI is 1200 panel. On the previous project, I could connect to the PLC and use...
26
18,791
Hello. I need your help. I work at STEP7. There are two CPU 317-2 PN/DP controllers (317-2EK14-0AB0), working on PROFIBUS, as Master (CPU_1) and...
69
This is the first time I am working with Simatic Manager Step7 as I started my siemens journey with TIA which is pretty easy and do a lot of stuff...
168
When you download a DB, the values get overwritten by what is in the "actual" column in offline DB. Does this happen at the start of the PLC...
157
Hello Inside a FB, I´m trying to transfer a string from a DB to a IN_OUT var that was define as a UDT. The problem is that i can´t determine the...
153
