Stepper Runtime errors (HSTP1)
bmm251
Oct 2006
Pittsburgh
Does anyone have a sample program for AB SLC500, 5/03 using HSTP1 stepper controller card? We are working on a project and cannot get the simplest output out of the SLC. Command errors...
Thanks,
Jason
I do not have any sample programs right now.
But I remember you need to load the Configuration values of the card, - say upon first scan - in order to clear the fault light and turn the card ready.
Regards
_______
The problems in particular that we are experiencing are Command Errors. The follow are some steps that we taken by us in order to get program to work.
1.We configured the Stepper Controller Module (1746-HSTP1) for a CCW limit switch, a home limit switch, and a pulse/direction stepper function.
2.Once Configured,we placed the program in the RUN mode then switched the appropriate bit from Configure to Command Mode (O:3.0/15)(We are using rack 3 for our module).
3.Once in command mode, we experienced an Invalid Position error (O:3.0/10).
4.Since our project was in the home positon to begin with, we used the reset position flag to reset the invalid position error.
From here is where we start to get some command errors. We start to program the PLC to get the stepper motor just to function. We set the stepper position to 10,000 pulses (O:3.2 set to 10 in decimal format), the velocity for 400 Pulses/sec (O:3.5 set to 400in decimal format), and the acceleration /deceleration to 10 Pulses/msec/sec (O:3.6 and O:3.7 to 10 in decimal).
5.We pressed a start button and set the relative move bit to the TRUE state (O:3.0/1) to make the stepper motor to do something. We received Command errors with this simple setup and our position and acceleration/deceleration data erased.
If someone out there can help me out with my programming I would appreciate it. Maybe my way of thinking is messed up.
Thanks,
Brian
HI everyone! I am trying to use a Micro850 to control a SureStep (Leadshine) Stepper drive (DM805-AI) from Automationdirect. I have no trouble...
200
Hi everyone, This is my first time posting, so please forgive any omissions or mistakes. I am attempting to control the velocity of a stepper...
18
1,077
Good Afternoon, I am hoping somebody can advise me on a make/model for a stepper drive. I have a failed ACS drive that worked wonderfully. I am...
702
I'm controlling an Applied Motion HW23-601D using a Leadshine EM542S connected to a 2080-LC50-48QBB, using CCW, and experiencing some weird...
624
Hello. I am using the following: Eaton E4-AC-12RXP PLC I am trying to control the CL86T which controls a Closed-Loop Stepper motor. I am using...
986
