still wondering
ronpittc
Jun 2003
San Francisco CA
I work in wind turbines and to explain how the turbine works...
The wind turbines as we all know they need enough wind to start, in this case the turbines are automatic, they have instruments (which are connected to the PLC) that senses the wind speed and the direction of it. And after sometime if it senses enough windspeed to run it will go ONLINE (which appears in the monitor of the control panel)and the propellers will start spinning.
Stages of Wind turbines before they start which appears in the monitor of the monitor for the PLC.
1. Run Mode - means it starting up
2. Tracking Mode - sensing and testing itself if there is enough windspeed to start
3. Blade Roll mOde - slowly testing the propelers and break releasing
4. ONLINE - Doing its job.... full spin it produces power (brakes full release).
OFFLINE (which is the status of the turbine,which means it is not doing its job to spin because there is not enough wind to spin to generate power.
and here is our problem.
After a good windy day, after the turbines worked. I myself check the status of the wind turbines( if there is anything wrong both for the system and electrical. And from the outside I can tell that there is not enough wind to start, so im expecting to see in the PLC monitor status (it should indicate that it is in OFFLINE mode). But the thing is , it indicates or shows that the turbine is in ONLINE, RUN MODE, Blade ROLL MODE wherein the wind turbine is not moving or spinning at all and the brakes for the propellers are not retracted too.
So what we do to solve this problem, we try to turn off the power of the PLC and the control panel (which is the one controlling the automation of the turbine) and wait for 15 sec. and turn back the power ON. In this manner the PLC starts to initialized the condition of the wind turbine and shows the right status of the windmill and begins to do tracking mode and the incorrect reading is gone. (and also the break release is activated- which indicates the windmill is running well.)
This happens everyday , so i have to reset the power everyday just to make it run.
Our problem is we dont know what causes this error and it appears everday. is there a solution to it?
Hi again, Im back with the same question... people here in PLCS told me its the power supply issue, i'm kinda uncertain about the answer because, the PLC has a separated power supply and it does not rely on the Wind Turbine. "we use AC and DC electricity separately to power our control panel, PLC and other peripherals, with that all those peripherals functioning it allows the turbine to operate and to create power going to the substation.
Why is the configuration IP different from the actual IP address still able to run normally?
839
Just started working with some HART loops and I'm trying out Pactware.I'm using Krohne and it works just fine recognizing my modem. I downloaded...
1,428
Square D had a group that wanted to develop PLC compatible power monitoring. They worked out of the Cedar Rapids circuit breaker plant - before...
834
When a servomotor is stopped, are its three windings supplied equally with the same voltage value or close values? The servodrive is supposed to...
1,406
We have this sub-system that was installed back in 2009, was never used, the building that used it was shutdown shortly after installation, and...
1,169
