Stratix Switch 8000
Hi and Welcome to the Forum!
This is the simplest way to reset the Stratix 8000 switches to default...
54245 - Stratix 8000/8300: Reset to Defaults (with Video)
Access Level: Everyone
I actually had to perform a reset on a Stratix 8000 two weeks ago. It reset to defaults with no problems using the above method.
This can also be very important after a reset if attempting to access the Device Manager via a web browser; depending on the firmware revision currently running in the switch...
64065 - Stratix 8300/8000/5700/5400 Initial Power Up Password
Regards,
George
What happens if you power up a 1783-MS10T with a Compact Flash card from a 1783-MS06T? Does it work, but with the "extra" ports unconfigured? If...
94
Helllo, I have to install new startix 8000 switch and want to communicate with 4 1756-EN2T module in 4 different chassis. How it will be done...
2,163
Hi Guys, I have a Stratix 5700 managed switch that will connected to another different network thus: Stratix 1 on 10.50.3.xx >connect through...
132
Hi, I have tried to connect multiple PLCs through backplane and am having difficulty. I have created a path from EN2T (192.168.199) --> ETAP1F...
432
I am currently wrapping up a startup of a couple lines of equipment in Asia. Cabinet has A/B 1873-US6T2H unmanaged switch with 6 copper ports and...
1,163
