String Comparison in Mitsubishi FX3U PLC?
Domomod
Nov 2012
Southern IN
Hello all,
I need to compare the first three digits of a barcode string to a known value.
I have the string being pulled from the Serial buffer, and placed into memory.
I found the instruction " $= " in the GX Works 2 help as a string comparison. But it seems like the FX3U PLC does not support this instruction.
If I can't use the string comparison, what are my alternatives to compare these values?
I did not look up the manual for the FX3U, but the usual alternatives for manipulating strings are:
(1) use a string or ASCII instruction that extracts (separates) the first 3 characters and places them into a new string, or
(2) use a string instruction that searches the string for certain characters, or
(3) use a string instruction that compares two strings, AND
(4) use a string instruction that converts a string to an integer number value, AND
(5) compare the new number value to a known value, using a EQUAL, LESS THAN, or GREATER THAN comparison instruction.
Look in your PLC Help file (or your PLC programming manual) for string or available ASCII instructions.
Hello! I have review PLCS at least half a dozen times and it occurred to me I might be able to crowd source a solution for something I have been...
3,006
Hi, i am trying to compare a string value in an IF statement My string value is user defined string called Barcode_String max characters 26...
7,365
Hi There, I am programming a cmore EA9-T87 to gather the data and save on SD card. And this time I want to use barcode scanner to trigger the bit...
3,515
Good afternoon to all. I'm new guy on this forum. I'd like to ask you for help with task like this: My boss gave me a program to modification...
12,939
Hi Is there an instruction for string compare mode in SLC5/05? cos I wanna compare two descriptions. Thanks in advance gorillaz_sg
1,913
