String data on PVP
NachoLibre
Feb 2017
Guadalajara
HI everybody:
I make a migration from a pv 550 to a pvp 6 600, my issue is to display the string data on the display. All what i can watch is "????????". i tried to change the tags and create again the display box but in any case it works.:cry:
Whole parameters are exactly as the pv 550.
What can i do??
Welcome to the forum! Do all the other objects on the screen display correctly? Does a numeric display show correctly?
Perhaps if you post a screenshot of the properties of the string display, we might be able to suggest something more - otherwise we are just guessing.
Welcome to the Forum !
Is the PLC the same type, or have you migrated to a ControlLogix or CompactLogix family controller ?
Post the exact syntax for your string display object Connection.
For a SLC address the tags will have the format {::[topic]st8:1}
On logix they are normally {[topic]tagname}
You also have to configure the topic for local and remote operation. You need to create a topic and apply the PLC location to it in RSLinx Enterprise Comms. This is used to test the screen from FTV. You also need to copy that information to the remote configuration. This is used by the screen to talk to the PLC.
If you monitor the screen in FTV by pressing the PLAY button you will get diagnostics in the bottom of the screen.
Hi, I'm new with ST and especially data structures and I am trying to create a data structure to store the following shapes and properties...
603
I am needing to transfer some prod_cons tags where the data type is a string[10]. Can you move a String data type? Thanks in advance RM
18
3,533
Hey folks! I've gotten an idea in my head and I'm wondering if anyone can help - and my title is terrible because I'm not good at articulating...
1,041
Hi all, I have a customer that is asking for a recipe of 200 recipes to be sorted. I'm trying to do this by way of a bubble sort. Basically my...
18
3,548
I have a customer that sent me the email below, I have been trying to find an answers in the manuals but cant find much to help He is using a...
4,444
