Structured text in factorytalk view studio?
Crailberry
Feb 2016
Utah
Just had a quick question regarding structured text in factorytalk. I would assume this is possible.
Is it just like rslogix5000 structured text? Because I've written a program in a Red Lion before, and the "structured text" it used seemed to be more like C++ more than anything.
If you can use structured text in factorytalk, whereabouts in your utility tree would you go to implement something like that? Is there maybe a tutorial floating around?
Thanks!
No Structured Text in FT View.
Certain objects can make use of the command language to control tag behaviors or object appearance and animation. The command language is accessible in any field that has an expression.
VBA is another option for accomplishing similar capabilities. There is much more flexibility with VBA particularly in working with ActiveX or other external programs.
But no Structured Text. The HMI is not a logic solving machine like the controllers.
OG
Hello, doing switch from FBD to ST. First task is converting my old work. How do you sum variables? For example, Interlock1, interlocl2 and...
193
Hello, I am using studio 5000 pro and am trying to figure out the structured text. Here's my scenario: An operator scans a barcode, the barcode...
352
I have an expression in a structured text routine of a Logix controller that looks more or less like the following: ResultInteger := Integer1 *...
441
Good evening. I display the step number of a SFC on a display. Sometimes, on a trip, it goes quickly through many steps and I need to prove to...
183
I am trying to set up a piece of equipment with a Horner HE-X4R. I'd like to use structured text and so far I'm just trying to get a basic On/off...
108
