Structured text newbie
PiperJohn
Mar 2022
Michigan
61
Hi folks, I am grateful for the opportunity to learn from you guys.
As an old school electrician I've come a long way with Allen Bradley.
I started out with Plc2 and worked my way up to the 5580 guard logix controller without any formal training.
I'm now trying to learn Structured text. I understand the basics but I am having a hard time understanding motion commands.
In ladder logic there's instructions like Maj, Mam, etc. How does this work in ST?
I've read some of the help files in Studio5000 (somewhat helpful) but i was hoping you guys could help steer me to a resource that'd be helpful.
The ones I've come across are too basic or way beyond me.
Thanks.
Thanks.
I have very little programming experience with RSLogix but I will still assume that the instruction are the same in LADDER and ST, that is if the instruction is available in both languages; some may be limited to ST.
Various functions are limited to ladder/st/fbd. the most moronic one? SCP. Scale with Parameters. it was avail to Ladder in 500.. in 5000? FBD Only on install. Though you can easily add it as an AOI.
help file said:
Structured Text
MAM(Axis, MotionControl, MoveType, Position, Speed, SpeedUnits, AccelRate, AccelUnits, DecelRate, DecelUnits, Profile, AccelJerk, DecelJerk, JerkUnits, Merge, MergeSpeed, LockPosition, LockDirection, EventDistance, CalculatedData);
Type a MAJ in your structured text "MAJ();", put the cursor on it and hit F1 on your keyboard, you can view the help file for it.
Can't help with Motion, but it's worth pointing out that
XIC varIn XIC varTemp OTE VarOut translates to
VarOut :=varIn AND varTemp;
Not
If varIn and var Temp then
varOut :=1;
else
varOut:= 0;
EndIf
For rockwell - best sticking with Ladder and FBD if you do need to use ST then use it for things like calculations as its not so easy to debug.
Rockwells ladder is very good and very powerful.
Now if you were using a Beckoff(codesys) PLC i'd say do most in the ST language as the ladder sucks.
Interesting points, thanks.
I'm not writing a program. I'm trying to make heads or tails a newer machine in our plant.
To make matters worse, it's all written in Italian.
Unfortunately I only have Studio5000 basic at the moment. I did borrow the Pro version a while ago and copied a hard copy of the program just to try and understand ST in my free time.
I looked through the entire program and did not find any Mam or Maj commands.
The only code I found that seems relevant was enable drive and start commands.
I presume the individual parameters are written elsewhere.
Is there a sample motion program I can look at somewhere in English �� where I can learn the ST syntex?
Thanks.
Thanks.
Can you post the code you have problems with, no need for context, just a sample of what you described. The reasoned for that is I get the impression you or I are/am confusing DT syntax with Rockwell instruction use in ST. Structured text syntax is very simple and limited to a handful of instructions, some of which are used often like IIF and CASE FOR, and of course assignments, and some that are not used all that often, I can only think of WHILE right now.
Rockwell instructions on the other hand are plenty and very specific to their platform; you would have to read their documentation to learn how to use each.
The only problems in learning ST is the syntax, for example FBD functions are simple usually input pins on the left output pins on the right, however, in ST this is often the reverse, the other things are the use of brackets, & line terminators i.e. ; as posted above, the ST language is loosely based on Pascal.
Can you post the code you have problems with, no need for context, just a sample....
Thank you! :geek:
Below is code for servo driven press section of machine.
The program doesn't have a MAM anywhere to be found. Coincidentally, the 19 parameters between ( ) are the same number (19) as a MAM instruction.
MOV on the other hand oly has (10 parameters)?
This press moves two servos at once A416 and A416.
I omitted A416 at the bottom (duplicate of Positioner A415)
// PRESSORI MOTORIZZATI //
MOV_GUIDE(A415_MoveGuide,CICLO_PRESSORE1mot,A415_Posizionamento_ok,A415_Errore,Marcia_Assi,RESET_ASSI,TIME_CLOCK,Errore_Guide_PRESSmot1,A415_Start,A415_MoveGuideDurata);
MOV_GUIDE(A416_MoveGuide,CICLO_PRESSORE2mot,A416_Posizionamento_ok,A416_Errore,Marcia_Assi,RESET_ASSI,TIME_CLOCK,Errore_Guide_PRESSmot2,A416_Start,A416_MoveGuideDurata);
Positioner(A415_Motion,
A415Axis,
A415_TARGET_POS,
A415_LIM_MIN,
A415_LIM_MAX,
0,
A415_Start,
RESET_ASSI,
Immediate_ESTOP_F,
Delayed_ESTOP_F,
0,
A415_Velocity,
A415_Acc,
A415_Dec,
A415_Homed,
A415_Locked,
A415_Errore,
A415_ErrCode);
Ok I see if input Sb932.10 button is pushed a one shot scan will make One_Shoot_On true.
Then If Pressore1 and 2mot is at press cycle (step?) 0, it will move it to a target position of 1000 and change press 1 and 2 cycle to 10?
Am I close?
// Alza manuale pressori
ONE_SHOOT_ON(OsrManPress, SB932_10, OSR_SB932_10);
if OSR_SB932_10 and CICLO_PRESSORE1mot = 0 and CICLO_PRESSORE2mot = 0 then
CICLO_PRESSORE1mot := 10;
CICLO_PRESSORE2mot := 10;
A415_TARGET_POS := 1000;
A416_TARGET_POS := 1000;
end_if;
Hello, I am using studio 5000 pro and am trying to figure out the structured text. Here's my scenario: An operator scans a barcode, the barcode...
249
I have an expression in a structured text routine of a Logix controller that looks more or less like the following: ResultInteger := Integer1 *...
390
Good evening. I display the step number of a SFC on a display. Sometimes, on a trip, it goes quickly through many steps and I need to prove to...
133
I am trying to set up a piece of equipment with a Horner HE-X4R. I'd like to use structured text and so far I'm just trying to get a basic On/off...
72
Good morning. I'm doing a rehab and I need to recycle some part of the old code that won't change and that I need. This is a calculation that...
22
1,372
