Structured text
gas
Nov 2005
Erie, Pa
531
We are selling a product that runs B&R Automation Studio programmed in ST.
I haven't used ST in a number of years so I need a refresh.
Which should I review, C, C++, C# or Python?
Other comments appreciated.
Thanks in adveace
Fortran and gawk ;)
But seriously, review ST; it is its own language, more or less.
Syntax/grammar are picked up quickly and so are irrelevant; vocabulary - knowing the libraries and instructions available - takes longer.
ST is loosely based on Pascal, however, like other posters there is plenty of articles on ST programming and probably B&R have their own documents on the subject.
I think ST is more than just learning the syntax, it is learning the way to set out ST for common automation scenarios.
This guy, Tom, in the Netherlands has a book on ST. It is called: PLC Controls with Structured Text (ST) - IEC 61131-3 and best practice ST programming
PM if you have you have any questions. I program almost entirely in structured text.
Each language has its pluses and minuses.
Structured text is a very powerful language for plcs in my opinion.
Most B&R programming is in ST, so all the sample programs and sample function block code snippets have an ST version, and the top of the help tree has [Programming -> Programs -> Structured Text] for a refresher on syntax and available keywords.
ST is Pascal based, but reading through a book about ANSI C would be more helpful than Pascal, especially for B&R. B&R uses some very C-like functionality in their ST (as well as offering programming in ANSI C directly).
You should take the time to learn what a pointer is and how it might be useful. A ton of B&R example code uses `t->.element` pointer dereferencing notation and I remember being a bit lost when I first started out, not even knowing that `t` was a pointer or really what a pointer was.
I´ve being trying wrap head around FOR loops.. When and what can this be used for? I´ve mostly seen it move data, resettting arrays etc. I made a...
401
Hi! When is CASE preffered? CASE uses a numreric variable for the cases and doesnt handle BOOL, but this can be done with numreric and bool using...
174
Hello, doing switch from FBD to ST. First task is converting my old work. How do you sum variables? For example, Interlock1, interlocl2 and...
221
Hello, I am using studio 5000 pro and am trying to figure out the structured text. Here's my scenario: An operator scans a barcode, the barcode...
389
I have an expression in a structured text routine of a Logix controller that looks more or less like the following: ResultInteger := Integer1 *...
476
