MorphuisOGrady
Hi Gents,
I need to make some changes to an existing Logix5000 program. Currently the machine fills with product based on time.This has to be changed based on weight now rather than time.
What I need to do is monitor the weight after the minimum feed weight has been reached and then "If the weight has not changed by X Kg in Y secs it must be full" and therefore we can advance the sequencer.
If someone were to describe this what would you call the parameters X any Y? Is there a mathematical function which would apply here?
Thanks for your help.
