Studio 5000 - Hide UDT name in tag description
FreeAtLast
Mar 2019
Nashville
38
I'm using Rockwell Studio 5000 V32.
Does anyone know how to hide the UDT name from the tag description when tag descriptions are displayed?
Instead of hiding all tag descriptions, I want to be able to write an occasional description above a tag, yet leave all other tags description free. The problem is that if descriptions are set (in options) to be displayed, it automatically shows the name of a UDT as the first line of a tag description.
UDTs combine the tag description with the UDT description.
Take a look at the UDT definition and look at the individual member description column. Whatever is in there, will be combined with the tag description.
This is referred to as "Pass-Through" descriptions. If you open the Controller Properties and select the Project tab you can turn this on and off. Note that this affects the entire project. So if you have a description applied to a timer, that description is also passed through to the done bit, accumulated value, etc. When you see these tags in the tag window with descriptions that are grayed out you will know that those are pass through descriptions. You can manually type in your own descriptions to override those if you choose. But for UDTs they go a step further and actually combine descriptions.
OG
Thanks. I had cleared out all the individual udt member descriptions, but I didn't realize that the description shown above my tag was actually from the parent I was aliased to.
Erasing the descriptions of the aliased tags fixed the issue.
Hi Everyone. Not posted on here for a long time, but I am hoping someone can help me. I am doing a differential pressure calculation in a L27ERM...
291
Hi, how do I convert 2x Integer registers to a Real? The two integers are from Modbus registers that contain a floating point value, I need to...
123
What is the best way to extract the hour and minute from the register that comes from Yaskawa VFD. In studio 5000 I have a register saved as INT...
127
I have an Allen Bradley temperature switch that I am trying to use in studio 5000. I am getting the message "Unable to interpret the IODD file"...
78
Hi all. I want to ask what may seem a stupid question, as I have a project to send live data to a Yeacode line printer which will print meterage...
203
