StudioLogix5000 Mini
gbradley
Apr 2002
Corona, Ca.
1,637
I have Two legitimate copies of RSLogix5000 Mini editions.
One serial # (16xxxxx181) that I use on my Laptop here, and another serial # (16xxxxx842) that I use on a Machine that is located overseas. (Not my real serial numbers) ;-)
I just recently Updated my Laptop to V34, but I don’t remember which Serial number I used.
Is there a way to figure it out?
I’m guessing that the software doesn’t keep track and that I only need the serial number for upload and Factory talk activation.
I checked the About info, and I can’t find anything.
I going to need to add V34 to the overseas computer, but I don't want to pick the wrong serial number.
I found out in my notes which serial number that I just used to download V34, so I will use the other serial number for my overseas machine.
For future reference the serial number entered at installation:
1. Has to be a valid serial number through their checksum for RSL/S5K. (RSlogix 5 & RSL500 used to allow any number after the first 4 - I found that out by it accepting a typo and running fine.)
2. The 'Family" of the serial number (first 4 digits) determines the edition - Pro, Full, Mini, Enterprise, Regular that is allowed to run.
I have 5, 500 & 5K installed on 4 desktops and a few laptops all with the same serial number, just only 1 license on the USB-Dongle that I carry around with me.
Hi, I am looking for some help with a GE Fanuc Versa Max Micro Controller model IC200UDR001-BF connected to a Quickpanel mini display...
151
Is it possible to connect a PC to the mini console's RJ12 connector? use an RJ12/DB9 cable?
984
I crimped a cable with this (attached) connector back a few years, but the company it was going into had the tool. Could someone please advise...
2,940
Can anyone recommend a device i can use to remotely connect to a servo drive which uses a mini usb port. I need to be plugged in to look at...
1,188
Hello, Do you guys know of any online vendors who can do a pre-fab of MINI DIN8 male connector to a stripped cable? Looking to interface DIN8 port...
1,153
