Stupid PF700 question
Dec 2010
Burlington, NC
402
I tried searching for the answer, but no luck verifying that I am thinking correctly. I have been brain farting here.
On a PF700 drive, in regard to the status bits for RIO/Enet communication, bit 1 is "active", does that mean the same as running (ie not faulted and driving motor regardless of at speed or not)?
Thanks in advance
Mark Snodgrass
If you have access to Rockwell's Knowledgebase you might look at this tech note 40046, I'm not sure if it is what you are looking for or not
Do not have a PF700 manual at the moment but from the PF 750 Manual
"Bit 1 “Active” – Condition is true if drive is modulating."
to me that means that the output stage of the drive is active - ie the inverter is sending/receiving current to/from the motor
I think that this bit will be set when: motoring / regenerating / DC Braking / Catch a spinning motor / Autotune
Bit 16 “Running” – This bit indicates that the drive has successfully responded to a start signal. The “Active” (Bit 1) status bit will also be set at the same time as the Running status. The “Running” bit will remain set while the drive’s control loops are active and during a controlled stop. The “Running” bit will be clear due to any of the following conditions: drive stopped, drive coast stop, drive jogging, drive autotuning.
Been working with PLCs for a couple of decades, but almost 100% DirectLogic. Have a customer who wanted me to make a couple of simple changes to a...
1,129
New to the EcoStruxure programming software (I'm an AutomationDirect guy) and I've been banging my head against the wall trying to figure out how...
1,033
All Performed a managed ROCKWELL download before lunch. When it was finished it opened the file folder of were it loaded too. Customer called and...
1,478
I have 3 valves that I need to open for 1 minute every 30 minutes, but not all at the same time. I have one TON timer (Start Blowdowns Timer)...
4,635
I just quit my job lol 12 years of not being apricated and being treated like your nothing to them spending years learning new skills that saves...
50
10,942
