Suggestions for an application
tomfarvour
Aug 2007
Green Bay
36
Hi all,
We are going to be impmlementing a card reading solution for a client of ours who has a wash that uses a SLC 5/03 configuration connected to a modem. The issue we have is that the cardreading solution needs to use an authentication database that will be on an embedded PC. The card reader will be connected to a Serial port on the embedded PC and another port needs to some how communicate with Channel 0 on the SLC 5/03.
Obviously the communication between the embedded PC and the SLC 5/03 is easy, and the SLC 5/03 and the modem, using an RS-232 smart switch/relay.
Here is the dilemma: When dialing in to the modem I can send an extra control string to the smart switch and tell it to goto Port A, which may be the PLC. I could send another to get on using RAS to Port B. That's no problem. The issue, I guess "question" i have is would I be able to have the on-site Embedded PC directly access the PLC. i.e.: Port B -> Port A?
-Tom
Hi guys. I would like to sense coated web running on a chained conveyor. The application looks something like this. Material fed through a coater...
22
6,095
I know this topic has been brought up a few times, but i had some specific questions. I have installed several 1783-NATR devices and they have...
343
I'd like people's opinions on which manufacturer of hardware they prefer. We are an aerospace manufacturing facility that does little to no SCADA...
546
I am setting up control for Hypochlorite dosing. The easy part is the dosing calculation for flow pacing but I would also like to setup trimming...
972
I'm working on an application and have hit a bit of a snag. I need to find an industrial touchscreen display that can: - Tolerate down to -40C...
776
