Sum part of an array starting at element 70
My guess is the FAL solution will solve in less processor time simply because it is a firmware solution. The function has been optimized for use in the target. But I have been wrong before.
Keith
It works yes. Is it the correct use of the instruction?
Here's how it would have been done on a PLC5, you can see from the usage that N7:70-99 become marked as used because of the length of the FAL
Converting this to Logix produces this:
An Alias is created automatically pointing to N7[0].Pos
Tidying it up without the conversion tags.
I know that will work but how do you know it's better... or more correct maybe... to use the offset in the expression instead of loading it into position element?
It's cleaner on the rung to be sure but that doesn't mean its right or wrong.
More correct because the FAL can do much more. If you had a temperature data array[100] and you want to convert 30 temperature values from Fahrenheit to Celcius and store them back in the array you could do something like this, where the destination is part of an array.
Hi again, I´m still working on the upgrade from 500 to 5000 of this program. I found something that I cannot explain, in RSLogix 500. It seems...
825
First, a background on the equipment so you know what is going on. I have an AB ControlLogix L63 processor controlling some Mitsubishi...
17
6,025
hello, I am a beginner and also new here, I was reading something about PID loop, there is two tanks , each with a sensor of pH, the control...
3,092
Hello all, I'm trying to recreate the following checksum calculation in the PLC. The example is written in C++ of which I am not very familiar...
3,070
Sum
Good Morning I am using rs logix 5000 and i would like to sum the values in an array without having to add each one in a CPT and at different...
1,664
