Suspect Dead 1756-L61S
collinsd70
Feb 2014
Swindon
195
Hi All,
I have been working on a home rig that has a 1756-L61S and the relevant safety partner.
Have owned for a long time and never had any problems until today.
I have powered up and everything was working okay and had a program loaded.
Came back to the rig around 20 mins ago and found no lights on the CPU (not even an illuminated OK light). Safety partner still shows a green OK.
Have tried in another rack, same issue. Tried another CPU in the chassis- works okay, so looks like a module problem.
Anyone know if there is a hard reset on these cards? or anything else to check?
***UPDATE***
Left in the rack for 10minutes and the CPU is operational again, has anyone else seen similar behaviour before?
Bent/Corroded/Broken pins? Not seated in properly and just had an issue today?
yeah first time today. checked all the pins previously- all fine.
still working at the time of writing this so looks to be okay now.
thanks to everyone for their comments.
Hello, I have a DB (22 gigs big) that is suspect and not working anymore. I found this repaircode on internet: EXEC sp_resetstatus SOADB; ALTER...
4,686
Hi guys, I have a machine that has been acting up a few times lately. It looks like it "forgets" it's position. The position comes from a...
1,443
I have a 1769-SDN DeviceNet scanner attached to a MicroLogix 1500, flashing 75 63. (No traffic, node 63). The highly suspect part is that the...
2,400
I currently offshore on a platform doing a pre-start check of some equipment and I have a pressure xmitter that's causing the Underrange bit to...
3,569
Had a callout today, machine I built in 2019 (Feb) with a 1769-L16ER-BB1b. Major fault, local IO module (there is no point attached). Reset major...
2,255
