Switch between different .mer file
Hojland
Oct 2006
Langå
203
Is there a possibility to switch between two different .mer files on the same panelview. I would like to make a button, that will make the panelview load another .mer file
Look into the Go To Configuration button but you will have a lot more access to other things also. Not sure if this is what you're after.
Not sure if this is a capability of a panelview. I would venture to say NO. There is a lot of stuff that loads up when you start an application. Alarms/Messages/Screens etc...
Just a thought though... why don't you create one application that has all the screens that you are trying to access? You could also create logins that prevent certain users from accessing certain screens etc...
Ok, I've setup comms to PLC's that are behind a NAT switch before, but I have not had a PLC behind one NAT switch communicate with a second PLC...
3,435
Dear Expert, I'm in a problem where I need to run my G120 CU250S in speed control PID mode and in a torque mode. The switching is done by DI0and...
1,593
Hi guys: I have two Stratix switch, one 8300 layer 3 switch and another 8000 switch downstream. I created VLAN 60,61 at 8000 switch by below...
5,626
dear all what is the difference between SEW BSG 825 459 && BS24 826 763 I asked about the usage as I see the circuit diagram are the same for...
1,354
I have a Horner PLC which is cable of doing RS-485 or RS-232 serial communication as well as ethernet. I am using this in conjunction with a...
2,831
