Switching an Automate 30 Processor to Run Mode
Mar 2014
Youngstown, OH
Hello,
I'm working with a Reliance Automate 45C307 processor. After powering off the machine the run indicator is out. I have a backup copy of the APX version 3.0 software successfully running under Windows XP but I cannot go into online mode. Is there any way to test my serial connection to this PLC via a terminal app? I'm not sure if my problem is with the serial comms or some setting in the APX application. Or is there another way to get this PLC back into run mode I'm totally overlooking?
Thanks,
A.J.
APX software is the best way to switch it into run. Might try a Program called SlowDOS or DOSBox along with the APX software to get the computer to slow down and connect, just a thought. Might just have to have an old computer running Win98 SE or earlier with a real RS232 commport.
I would also try using a null-modem on the cable. Somewhere I have a cable I built 15+ years ago. I you cant get it to work, I will try to find it and trace the pin-outs for you.
You might want to browse this site for info:
http://www.automation-consulting.com/aps/aps.htm
And, here is a link to a manual from that site, see page 7-11 for some hints.
http://www.automation-consulting.com/aps/APSMan.pdf
Thanks. I'll keep plugging away at the APX application then. I can hook this newer XP laptop to another brand controller and communicate with it via the USB to serial adaptor. I found the original laptop the backup was pulled from. I'm shipping that to location. Hopefully it'll still work. Attached is a picture. (y)
Now that things are back up and running what would cause the processors to be knocked out of run mode? The rack has two processors and they both where knocked off. I'm assuming on power up the CPU does a system check and isn't liking what it sees? Any way to dig deeper into this problem?
A.J.
I had a unit many years ago that randomly dropped out of run. Had to replace the unit. I suspected that it was most likely a heat + age or time in service issue.
Maybe in your case it is a power issue and I would suggest you consider powering it with a good quality online UPS power supply to avoid power blips.
Hello guys, please let me ask if you have experience the same situation like this. Inputs are steady but the outputs OTE are switching off and on...
342
is this possible? i have a customer has has a large factory, he has 2 x 800amp supplies coming into the site and would like to switch between...
927
Does anyone have any experience with working on piezoelectric motor control? I want to use off the shelf components to hopefully change the...
751
Hello, I have a Ge Fanuc 90-30 system with a Cutler Hammer PM 3000 Power series HMI. Besides the HMI, the customer is happy with the controls side...
1,015
I'm working with a ROC800 program offline right now. Normally, you can switch your TLP view between text and numbers by making your choice under...
855
