Switching Tags in FactoryTalk View ME
agrajag42
Dec 2015
Bahstahn
17
I built my system with Logix Designer, FactoryTalk View ME, and Emulate 5000. I created two projects -- one to work with the actual hardware, and another to work with the emulator, thinking I'd pull code from the emulator project into the "real" project at the end.
I'm now realizing, as I want to switch over to actual hardware, that all my tags in FactoryTalk View reference the emulator project name:
{[PLC_project_emulator]sample_switch}​
instead of
{[PLC_project]sample_switch}​
Oops.
There's a *lot* of those links, many of which are in animations (visibility and color). Is there an easier way to change them over than the manual process I'm fearing?
Thanks,
/e
Select All -> Find/Replace
Export your tags to .CSV file, again Find/Replace, re-import them.
Ha! I didn't even bother to check find/replace, as I figured it wouldn't hit the animation stuff... but a quick test (which I should have done first) confirms that it does!
Thanks!
/e
Hello guys, please let me ask if you have experience the same situation like this. Inputs are steady but the outputs OTE are switching off and on...
340
is this possible? i have a customer has has a large factory, he has 2 x 800amp supplies coming into the site and would like to switch between...
925
Does anyone have any experience with working on piezoelectric motor control? I want to use off the shelf components to hopefully change the...
748
Hello, I have a Ge Fanuc 90-30 system with a Cutler Hammer PM 3000 Power series HMI. Besides the HMI, the customer is happy with the controls side...
1,014
I'm working with a ROC800 program offline right now. Normally, you can switch your TLP view between text and numbers by making your choice under...
854
